2000 Mercury Sable oxygen sensors
166,000 MILES • 6 CYL • FWD • AUTOMATIC
JLP10
My check engine light is on. My local parts store checked the code and it says bank two sensor two is bad. I replaced the oxygen sensor on the cyclinder bank closest to the firewall after the cat and the check engine still comes back on after resetting it. Did I change the correct sensor ? HELP ! Thank You !!
Sep 14, 2009 at 12:30 PM
RACEFAN966
  • 5,029 POSTS
Ok here is how it breaks down. Bank 1 is the right bank (closest to the fire wall), bank 2 is the left bank (closest to the radiator. Now sensor 1 is the one closest to the engine and sensor 2 is the one behind the cat. convertor. So no you replaced the wrong one. Now you know how they are labeled. Hope this helps.
Sep 15, 2009 at 4:31 AM
