2000 Mercury Sable lower radiater hose
MGOOSE
Engine Cooling problem
2000 Mercury Sable 6 cyl Front Wheel Drive Automatic
how do i replace the lower radiater hose
Oct 23, 2010 at 4:56 AM
  • 110,248 POSTS
The lower radiator hose is clamped on to the radiator and the waterpump. First, disconnect the neg terminal from the battery, drain coolant from radiator, then remove clamps and hose. Reverse the sequence to replace.
Oct 26, 2010 at 3:33 AM
