2000 Mercury Sable idle
19,000 MILES • 6 CYL • FWD • AUTOMATIC
ANTHONY_SLIM
I replaced the idle air control valve, the throttle position sensor and the mass airflow senso on my car and If the idle aircontrol valve is plugged in it revs up to 4000 rpm and if I unplug it it goes down to 400 rpm. I don't know what else could be causing this. I'v also been told that there is no vacuum leak.
Aug 28, 2008 at 9:45 AM
BMRFIXIT
  • 19,053 POSTS
I would check again for vacuum leaks
no check engine light on (I wonder )
scan the system for codes
Aug 30, 2008 at 11:09 PM
