2000 Mercury Sable headlights
130,000 MILES • 6 CYL • FWD • AUTOMATIC
SIXSHOOTER
  • 6 POSTS
low beams dont work but all other lights do i have checked all fuses relays and switches everything checks out great cant figure this out.
Aug 2, 2010 at 12:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
this is normally a sign that there is a bulb that is not working properly. test ALL bulbs, not just the headlight bulbs.
Aug 2, 2010 at 3:11 PM
SIXSHOOTER
  • 6 POSTS
what if everything checks out then what, cause everthing else works perfect.
Aug 3, 2010 at 12:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if your certain everything was good then must be wiring issue somewhere, either at dimmer switch or at one of the light assemblies.
Aug 3, 2010 at 1:38 PM
BRAVESTAR1
  • 234 POSTS
It could also be a ground problem with one of the wires that connects back to the cars subframe. I am working on this same issue with a 2002 Ford Taurus right now.
Aug 12, 2010 at 1:26 PM
SIXSHOOTER
  • 6 POSTS
ok i light tested the plug where the bulb plugs in and every prong is hot dont know if thats normal but they are hot,and i know the bulb is good i checked it in another car and its good any ideas thanks for all the info sofar
Aug 14, 2010 at 12:31 PM
SIXSHOOTER
  • 6 POSTS
man if you get yours figured out please let me know what it was and ill do the same thanks for the info.
Aug 14, 2010 at 12:35 PM
