2000 Mercury Sable cyclinder 5 missfire
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
KOZ84_02
just replace an engine in a 2000 sable dohc. has a rough idle and a few codes. p1151 fuel air metering p0305 and i dont remember the other code but it was for bank 1 and 2 running lean. When the car is in idle i can smell gas. the missfire is only picked up after i get off the freeway. i swapped the injecters, plugs, and coil from a know good cyclinder and no luck. I also changed the crankshaft censer and mass air flow censer
Mar 12, 2010 at 10:52 PM
BMRFIXIT
  • 19,053 POSTS
Check if coil firing troubled cylinder
do a compression test
Mar 16, 2010 at 1:17 PM
