ac cycles on n off after a short time --doesnt have time to really cool it off. it is cold tho. culd it be the ac switch n where is it?
Oct 11, 2010 at 7:43 AM
WRENCHTECH
✓Experienced Mechanic
It's most likely low on refrigerant because of a leak in the system. This would need to be verified with a set of professional gauges.
Oct 11, 2010 at 8:23 AM
GREATEAGLE
MEMBER
[quote:80906232ce="Wrenchtech"]It's most likely low on refrigerant because of a leak in the system. This would need to be verified with a set of professional gauges.[/quote:80906232ce] thanks, u r helpful. will do as u suggets
