p0171 codes?
210,000 MILES • 6 CYL • FWD • AUTOMATIC
TCABEL
I have a 2000 Mercury Sable. 4 codes are coming up. P0171, P0174, P1131, P1151.
P0171 system to lean bank 1
P0174 system to lean bank 2
P1131 lack of heat oxygen sensor bank 1 sensor 1.
P1151 heated oxygen sensor bank 2 sensor 1.
Any Sugestions on what I need to replace?
May 14, 2010 at 2:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
try cleaning out the passageway to the EGR and also have catalytic converter flow tested. something is probably stopped up and causing oxygen sensors to not work properly. if all is OK replace oxygen sensors
This guide can help us fix it
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
May 14, 2010 at 5:09 PM
BYLLH74
  • 26 POSTS
Hello, about a month ago, i put in new head gaskets and did valve job and resurfaced the heads. I got it all back together and now im getting a flashing ses (service engine soon) light. I scanned it and got code p0171 only. i hear a slight exhaust leak but done know exactly where its comming from. any help?
1999 mercury sable 159000 miles, 3.0 ohv
Jan 11, 2021 at 7:55 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Flashing check engine light is an indication of a misfiring and the code p0171 will not cause a flashing check engine P0171 check for vacuum leak and or exhaust leak you had mentioned that you have a small exhaust leak 1st step to correct the P0171 should be fixing the exhaust
DTCs P0171 and P0174 indicate air/fuel ratio is correcting rich for an overly lean condition. DTCs P0172 and P0175 indicate air/fuel ratio is correcting lean for an overly rich condition. Possible causes are:
Fuel system malfunction.
EGR system malfunction.
Air intake or vacuum system leak.
Engine oil level too high.
Incorrect cam timing.
Restricted air cleaner.
Faulty PCV system.
RUTHIE830
Engine light stayed on, mechanic fixed Vacumn flex line, replaced air plentum vacumn line under intake, cleaned fuel injection throttle body system and mass air flow sensor - took car went 6 blocks - died on me - accelerator starving for gas - what do you suggest?
Thanks, Ruthie
CARUNDELL
  • 602 POSTS
[quote:4f3a029111="Ruthie830"]Engine light stayed on, mechanic fixed Vacumn flex line, replaced air plentum vacumn line under intake, cleaned fuel injection throttle body system and mass air flow sensor - took car went 6 blocks - died on me - accelerator starving for gas - what do you suggest?
Thanks, Ruthie[/quote:4f3a029111]
Hey Ruthie
p0171 indicates a lean condition on one "bank" of the engine and usually does not "kill" the engine. I would recommend your tech:
-verify proper fuel pressure
-scan for any other codes
Let me know and we'll go from there!
Chris
SERVICE WRITER
  • 9,123 POSTS
Ruthie, howd you make out?
