1999 Mercury Sable transmission oil leak
199,000 MILES • 6 CYL • FWD • AUTOMATIC
CRAZYMURDOC
I had my radiator replaced recently and since then I have had a leak at the site where the transmission oil cooler line goes into the upper part of the radiator. I can manipulate the line and stop the leakage for a while, until it is "jarred" loose again. It seems as if something is not seated correctly or a part is missing. There was a plastic clip or something similar that was cracked and the problem still exists. Is there a piece that was lost when the radiator? Thanks, Teresa
Jun 30, 2008 at 9:06 AM
LEGITIMATE007
  • 5,121 POSTS
yeah you probably have a crack at the mouth of the hose and the clamp cant get a good seal on it , I would cut a little of the hose off (the tip) and put it on the radiator properly and clamp it correctly.
Jun 30, 2008 at 9:10 AM
