1999 Mercury Sable rack and pinion
150,000 MILES • 6 CYL • FWD • AUTOMATIC
BYLLH74
  • 26 POSTS
i have a 1999 mercury sable with a 3.0 engine and i also have a 1998 ford taurus 3.0. i wanted to know if the rack and pinion were interchangable. im putting the one from the ford taurus into the mercury sable. thanks in advance
Dec 22, 2008 at 5:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
I have interchanged many parts between the Sable and Taurus. Although I have never interchanged this specific component, I am certain that it will work. You can call your local Ford dealer to verify.
Hope this helps..
Thanks for using 2carpros.com!
Dec 22, 2008 at 5:32 PM
BYLLH74
  • 26 POSTS
i ended up changing my rack and pinion myself. loads of fun. anyways, the rack and pinion on a 96-98 taurus is different on 99's. they changed a bit in the year 99 and are the same through atleast 2004.
Dec 30, 2008 at 5:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Thanks for that info. It will help us better assist others in the future.
Thanks again for your donation and for using 2carpros.com!
Dec 30, 2008 at 10:59 AM
