When driving my 1999 Sable (95K miles) it will occationally loose power VERY briefly -- or so it seems. The tach will dip and the "Check Engine" light will flash on for a second. Then the car continues on its way. Usually when this happens, the symptom occurs once or twice and then goes away - sometimes for weeks. However, on rare instances, the symptom will continue almost non-stop - making the car almost undrivable.
I have had the tranny checked (twice) & it is not that. No diagnostic code is being left causing difficulty in isolating the problem.
A new ignition switch was put in yet the problem continues - although once every other week or so.
Probably unrelated, my "Low Coolant" light hasstarted to come on, and stay on -- even though the reservior level is full.
Feb 1, 2010 at 11:56 AM
