1999 Mercury Sable Low Coolant Lite
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
CBUCH1939
Recently begin receiving "Low Coolant" message when starting. Have checked coolant level, its right where it belongs, checked circulation in resevoir, moving right along, heat indicator remaining at mid line where it has always registared. Any suggestions?
Apr 20, 2008 at 2:16 AM
SERVICE WRITER
  • 9,123 POSTS
The sensor it self is bad. Sometimes you can tap on it to get it to respond. If not either replace it or live with the light and check the level avery so often.
Apr 20, 2008 at 2:51 AM
