my heater doesn't get hot and my air doesn't blow cold..but it blows. other then this there is nothing else wrong with my car
Oct 17, 2008 at 10:12 AM
RENAUDTN
✓Experienced Mechanic
Could be one of the following:
-You may have a bad thermostat: is your car long to warm up? If so, replace your thermostat.
If not forget about the thermostat.
- your level of coolant is too low.
-Your heater core may be clogged
-Your heater control valve may be defective
-your temp actuator may be defective
-You have a vacuum leak
Oct 17, 2008 at 10:21 AM
MEUDONNA
MEMBER
thank you ....i will have someone to ck this out.. do you know if it will cost alot of money to get repaired
Oct 17, 2008 at 10:24 AM
RENAUDTN
Just to clarify your first post:
You say you don't have heat when you turn on the heat, and you don't have cold air when the AC is on; is this correct?
Oct 20, 2008 at 1:12 AM
MEUDONNA
MEMBER
yes. it blows but not hot or cold.
Oct 21, 2008 at 2:24 AM
RENAUDTN
Okay, my bad, I read your post too quickly and thought your heater only was not working.
There is a common problem with your car: blend door failure. The lack of AC and heat is a symptom of this.
I would definitely get that checked out.
