1999 Mercury Sable Heater control not working
1999 MERCURY SABLE
293,000 MILES • 6 CYL • FWD • AUTOMATIC
JIMMYBOB007
We have no A/C any more. Only heat, hot. We can adjust the fan and select direction. ie: defrost, vent etc, but only hot air comes out. When on "auto" the fan does fluctuate like it should, but after a while we need to manually lower the fan speed. It has been suggested that a flap or motor has broken and the entire dash, including steering colinb, needs to be remover to get at the problem mechanism. Any other ideas are welcome. thanks in advance. I am hoping we can get at the problem area by cutting athrough the floor or fire-wall. My mechanic is somewhat less than enthused about this suggestion...lol
Jan 7, 2008 at 12:56 PM
JIMMYBOB007
Wow, thanks for your quick reply. I did the test you suggested. The code I received is 888
Jan 10, 2008 at 8:33 AM
JIMMYBOB007
Thankyou for your help.
Jan 10, 2008 at 9:46 AM
