1999 Mercury Sable DOHC (105K) Coolant Level Check Lamp
MTA
Recently the Coolant Level check lamp has begun coming on and off intermittently. The coolant mix and fill level are good and the engine temp gauge does not register a warmer than usual indication. Any thoughts on what might be the trouble? Thanks.
Jun 30, 2006 at 3:13 AM
EPERRY
  • 21 POSTS
there is a sensor in you overflow bottle make sure to wires are still intack if they are then chances are your sensor is gone.
Jul 19, 2006 at 4:37 AM
MTA
Had new coolant bottle installed (sensor is integral to unit). Problem resolved. Thank-you.
Jul 20, 2006 at 3:09 AM
EPERRY
  • 21 POSTS
glad i could help.
Jul 20, 2006 at 10:06 PM
