Cold air blowing from heater vents
JACKSON1
  • 1999 MERCURY SABLE
  • 6 CYL
  • FWD
  • 125,000 MILES
My 99 mercury sable blow's out very little heat. I have flushed out the heater core, replaced thermostat but still not hot air.I don't see a heater control valve in-line on hose. Any ideas?
Wednesday, November 13th, 2019 AT 5:19 PM (Merged)
RENAUDTN
  • 636 POSTS
Hi there,
Check this link; it could explain your problem:
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Hope this help
BROMART
  • 6 CYL
  • FWD
  • 11,200 MILES
The control is turned on heat, but very little heat is felt thru vents.
MASTERTECHTIM
  • 4,749 POSTS
Double check your coolant level. If it is a little low this will drastically effect your heat. Feedback and votes are appreciated.
KIARA1122
  • 6 CYL
  • FWD
  • 117,000 MILES
My heater is blowing cold air only. What could be wrong with it. I have had it in the shop they changed the thermostat. Said it woul;d work but it doesnt. Really need some advice before the temps drop.
  • 31,937 POSTS
Hi there,
The heater tap or the controller may have failed, to do a basic check, with the heater on& the engine at normal operating temp, both heater hoses going into the cabin should be hot to touch, if not there is no circulation through the heater and this will be the reason there is no heat in the cabin, check this out next.
Mark (mhpautos)
