1998 Mercury Sable Vents
125,000 MILES • 6 CYL • FWD • AUTOMATIC
TURBOHAUL
One morning after i start the car, i put on the ac, and i realized that no air was blowing out of the front vents, but ac from the floor and defrost vents. The ac control played no role when i switch from defrost to floor only or to front vents only. I checked the actuator and it seemed to be fine. What could be a possible solution and how to repair it ?
Jun 8, 2010 at 2:49 PM
BMRFIXIT
  • 19,053 POSTS
Manual A/C-heater controls are included in the integrated control panel, located near center of the instrument panel. A/C-heater controls include a function selector knob, temperature control knob and blower speed control knob. Function selector knob actuates a vacuum selector valve that controls vacuum to door actuators. Door actuators control position of outside/recirculation, floor/panel and panel/defrost doors. Door positions determine airflow modes (panel, floor, defrost, etc.). Check for vacuum leaks as it will default to defrost and floor in case of lose of vacuum
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic_78.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_720.jpg
Jun 9, 2010 at 9:42 AM
TURBOHAUL
One small problem. I can't seem to find where the vacuum hose is connected from the engine. Any diagram that could assist me in locating the vacuum hose fitting?
Jun 12, 2010 at 6:48 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic_82.jpg
Check under hood should have a picture of vacuum route
Jun 12, 2010 at 9:19 AM
