Transmission won't shift out of Park
DULEDAD
Transmission problem 6 cyl Front Wheel Drive Automatic 118,00 miles
This is a weird problem. It's summer now and my 1998 Sable shifts out of Park with no problem. As soon as winter comes and temperatures drop my car has to warm up before it will shift out of park. Any suggestions? Thanks! When it's really cold it can take 10 to fifteen minutes.
Jul 6, 2009 at 2:49 PM
BMRFIXIT
  • 19,053 POSTS
There is a shift interlock system that does not allow you to take the transmission out of park it must be getting worn and the cold weather is affecting it. I would replace the shift lock actuator or at least try to lube it.
(Here are some diagrams Below)
Cheers
Jul 12, 2009 at 12:45 AM
CLARENCE POHL
The actuator for depressing the brake pedal is in the steering column you will need to remove the cover first. I replaced the actuator and the problem is fixed, Thanks 2Carpros
Aug 26, 2016 at 5:16 AM
