1998 Mercury Sable The car seems to stop running on signal
SAM0072080
MEMBER
1998 MERCURY SABLE
6 CYL
2WD
AUTOMATIC
141,000 MILES
The car seems to stop running on signal stops. I can start it back on but I have to put it back in park before I can start the car again
I dont know where the problem is
Thanks
Sam
Wednesday, July 23rd, 2008 AT 1:33 PM
BMRFIXIT
MECHANIC
Check engine light on?
Get the codes
i would check for vacuum leaks
pcv valve and its vacuum line
check and clean idle air valve
check tranny for any codes
SPONSORED LINKS
Wednesday, July 23rd, 2008 AT 8:25 PM
TAILWHIP
MEMBER
Hi Sam - I have a 95 Sable Wagon that is doing the same thing. But, I've recently come to realize that this only happens when the air conditioner or heat is on. So on good days when neither has to be used the car runs fine. I'm looking for suggestions too.
Sunday, August 3rd, 2008 AT 10:23 PM
BMRFIXIT
MECHANIC
I would chean or replace the idle valve
Monday, August 4th, 2008 AT 6:48 AM
TAILWHIP
MEMBER
Thank you. I'll take it to my neighborhood mechanic.
