spark plug gap
1998 MERCURY SABLE
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEITHGLENN
need the spark plug spacing (gap)
Jan 24, 2009 at 4:58 AM
BMRFIXIT
  • 19,053 POSTS
3.0L DOHC .052-.056
3.0L OHV .042- .046
3.8L .52- .056
Here is a guide so you can install them correctly.
https://www.2carpros.com/articles/how-to-change-spark-plugs
. Please let us know if you need anything else to get the problem fixed.
Jan 24, 2009 at 5:15 AM
RALJO28
what do i do when my sparkplug
backs off and wont seat. This is on a 2000 mercury sable. DOHC. V-6
Apr 1, 2019 at 10:28 AM (Merged)
  • 31,937 POSTS
Spray a good amount of lube down around the plug, work the plug back and forth, with a mind to take it out, hopefully it is just carbon and not a crossed thread, try and remove the plug and run a thread chaser down to cut out any carbon.
DIBJIM
how do i get to the rear plugs on my 1999 mercury sable v6 dohc engine? 117,000 miles on car.
FAIRRACING31
  • 150 POSTS
[quote:9810c88ffc="dibjim"]how do i get to the rear plugs on my 1999 mercury sable v6 dohc engine? 117,000 miles on car.[/quote:9810c88ffc]
Disconnect the wiring harness from the ignition coil pack, remove the four coil hold-down screws, and remove the coil pack for access to the spark plugs in cylinders 1, 2, and 3. Or, you can remove the entire plantum which is what I do because it gives you more room to pull the plug wire's. You might consider replacing your plug wires if they are original at this time.
