1998 Mercury Sable Short causing drain on battery
100,450 MILES • 6 CYL • FWD • AUTOMATIC
EDFEETS
I have a short in the electrical system causing a 300ma drain on the battery when car is not running. This causes the battery to run down after a couple days to the point the car will not turn over. I have isolated the short to a 5A fuse#23 that is marked WIPE-VAP on fuse cover or GEM. When I pull the fuse out the drain basically goes away and the car will start after many days idle. The car will run fine without the fuse, but the power windows, power door locks, windshield wipers and the remote door locks will not operate. What does the fuse control and where do I look for the problem. Thank you, Eric.
Jun 6, 2010 at 2:14 PM
CARADIODOC
  • 34,417 POSTS
Hi Eric. Welcome to the forum. "GEM" is Generic Electronic Module. That's Ford's name for their Body Computer which runs all the things you mentioned. Isn't it funny that all those systems worked fine for decades but now they need an expensive, unrelaible computer to do the same thing? Sounds like something inside the module is not turning off, but don't overlook a glovebox light that is staying on.
caradiodoc
Jun 6, 2010 at 9:21 PM
