Very novice "mechanic" trying to save money[regret it already] I changed a water pump,tried to replace belt afterwards and cracked the pulley that is opposite of the power steering pump,I have the tools to remove and press on a new pulley but cannot locate all the bolts to remove the [block that this is located on]
I am considering removing the radiator fill tank[located across from the pulley on the left side] to possibly gain access with the tools without removing the block the pulley is on
I have removed three bolts from the area around the power steeering pump and cannot budge it
any ideas to save me?
thank you Jack
thank you Jack
Nov 1, 2009 at 8:24 PM
