1998 Mercury Sable plugged heater core
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
JJBRUG6
Would Draino or Baking Soda or some other liquid help? Would hooking up a Water hose direct w/a adaptor work?
How do I remove the heater core and replace it if I can't get it unplugged?
Sep 16, 2008 at 12:36 AM
2CARPRO JACK
  • 11,533 POSTS
That isnt really a DIY project, the entire dash has to come out of the car to get to the heater core.DO NOT hook a hose directly to it, this could blow the core out and then replacing it will be necessary.Have you tried having a radiator shop backflush the system? you can use a hose, but not full pressure, and try going both directions with it. I wouldnt use too harsh of a chemical there may be o'rings sealing the tubes.Simple Green may be worth a try.
Sep 16, 2008 at 1:00 AM
