1998 Mercury Sable need help
155,000 MILES • 6 CYL • FWD • AUTOMATIC
JCREYNA
my car wont start u turn the key and u here like a clicking sound like a relay all my fuses are good cant figure the problem need helo what could it be.
Feb 14, 2009 at 6:30 AM
HELPING YOU
  • 100 POSTS
Try jiggling the shifter and "N" instead of "P". (Nuetral safety switch could've failed).
Check battery (LOAD TEST), connections (power & ground), power to crank (little) wire at starter, etc.
Starters do fail - have someone hold key in "crank" position while you tap on the starter lightly - also see if you can feel/hear any clicking AT THE STARTER when someone tries it.
These are the most common probs. to begin with...
Feb 14, 2009 at 6:46 AM
