1998 Mercury Sable I think its the transmission
HOTBOY135PTZ
  • 1998 MERCURY SABLE
  • 6 CYL
  • FWD
  • 13,500 MILES
While i'm driving and coming to a stop, while the car is in drive, it starts to rev up or sometimes it will act like its in neutral. It also happens when I put the car in park. It just revs up. I haven't done any repairs to the engine or transmission. Just bought the car 4months ago and it was not working like this before. It has fluid in the transmission, correct levels. Was wondering with your expertise knowledge if you may know what could be causing this. Thanks.
Wednesday, August 13th, 2008 AT 11:45 AM
BMRFIXIT
  • 19,053 POSTS
Suspect idle air valve
check for vacuum leaks
and check motor and tranny mounts
Thursday, August 14th, 2008 AT 8:40 AM
HOTBOY135PTZ
Even when im driving and the light turns red, I come to a stop, I can feel the transmission like changing gears. When the like turns green, still in drive, I hit the gas and revs like in neutral. This can possible be caused by idle air valve, vacuum leaks and motor and tranny mounts? Could there be something in the transmission that has to be replaced?
Thursday, August 14th, 2008 AT 3:11 PM
BMRFIXIT
  • 19,053 POSTS
Have the tranny checked by your local tranny shop
Thursday, August 14th, 2008 AT 8:29 PM
