1998 Mercury Sable Heater Flapper door?
66,000 MILES • 6 CYL • FWD • AUTOMATIC
WRUSSELL4BB6
Basically the heat works but the door isn't opening to let the heat through into the airstream of the fan motor. Where is this door located and is there a way to open it manually and leave it open?
Nov 5, 2009 at 3:35 AM
BMRFIXIT
  • 19,053 POSTS
lets make sure its the blend door and not the heater core in need to be flushed
do a self diagnose test on the system and let me know what you have for codes if any
ENTERING SELF-DIAGNOSTICS
Ensure in-car temperature is 40-90°F (4-32°C) as false in-car temperature sensor DTCs will be displayed. Simultaneously depress OFF and FLOOR buttons, then press AUTO button within 2 seconds. The display will show a dashed line in center of display window for up to 30 seconds while test is running. Record all DTCs as displayed.
Self-diagnostics can be initiated at any time with the resulting DTCs being displayed. Normal system operation is stopped when system is in self-diagnostic mode.
Nov 6, 2009 at 11:06 AM
