1998 Mercury Sable Ghost is under my hood
1998 MERCURY SABLE
127,000 MILES • 6 CYL • FWD • AUTOMATIC
DANSAW
When I attempt to turn my car on...I hear only a clicking sound coming from under the hood. My friend tried to give me a jump but I don't think the battery is bad because the lights come on (and look strong) and my radio plays. My uncle thinks it could be the starter solenoid but when the car finally turned over today....when I got it home (as the engine was running) it just stopped. My uncle thinks it could also be a bad injector, fuel filter, or gas pump issue. What do you think?
Dec 1, 2008 at 10:46 AM
RENAUDTN
  • 636 POSTS
The clicking sound you heard was probably the solenoid.
Although your battery may seem strong, it doesn't mean that it is; the only way to know is to have it tested at an autopart store.
I don't think your problem is the fuel filter or fuel pump; check your battery cables for corrosion and make sure they're not loose at the battery/solenoid/starter. Also check your ignition switch; if it's loose it could result in your car turning off.
If you have a digital voltmeter and feel confident about doing more in depth tests, let me know and we can do more troubleshooting. If not, have a mechanic to look at the starting system
Dec 2, 2008 at 4:53 AM
