1998 Mercury Sable FUEL SYSTEM
TPHEGNER
Engine Performance problem
1998 Mercury Sable 6 cyl Front Wheel Drive Automatic
The Fuel pump is not getting any power Where do I start
Jun 20, 2008 at 1:06 AM
BLACKOP555
  • 10,386 POSTS
first check the fuse for the pump and the fusible links under the hood. if those are good check fuel pump relay and finally check or replace the fuel inertia cut off switch.
Jun 20, 2008 at 8:06 AM
