1998 Mercury Sable Engine Starting
93,688 MILES • 6 CYL • 2WD • AUTOMATIC
GMAN95120
My wife called me saying see couldn't start the car.
I met her and jump started the car successful.
I charged the battery and tried starting the car, which cranked very slowly and then not enough power to start and then the clicking sound.
I purchase a new battery and installed it.
At first attempt it cranked slow, then perfect starts for several days.
Today, I went to start the car, slow cranking, 2nd attempt even slower and 3rd attempt clicking.
I waited roughly 20 minutes and tried again; perfect strong start.
I checked battery, fully charge.
Could it be the starter... or something more complex.
May 15, 2009 at 5:05 AM
DOCFIXIT
  • 18,828 POSTS
HI
Classic starter drag the armenture is like a Roulst wheel each slot a pathe for electricity. When bushings wear and communtator wear at some point they land on a bad spot that draws big amps a cranks slow. Try again got lucky it stoped on a good spot. So replace starter verefy good connections.
Hope this helps
Thanks for donate
May 15, 2009 at 6:18 AM
