1998 Mercury Sable Engine sluggish and has high RPM
PFAFFLYJ
  • 1998 MERCURY SABLE
  • 6 CYL
  • FWD
  • 13,000 MILES
Hi, my car drives fine in town but when I get on the highway it is sluggish as far as accelerating and at 55 mph the RPM stays at 2000 even when I'm not pressing the gas. I just bought it 4 mo ago and they assured me everything was fine. Any ideas what I should do with it. It was not acting like this when I first got it. Thanks!
Wednesday, June 23rd, 2010 AT 9:16 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking, fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Wednesday, June 23rd, 2010 AT 10:15 PM
