1998 Mercury Sable
200,000 MILES • 6 CYL • FWD • AUTOMATIC
J-BIRD
Symptom-Sludge& Coolant backing up in reservior,over heating engine-Transmission will not go into drive without 2 qts. per day of fluid.I need to know the cause & remedy for this situation.
Aug 21, 2009 at 11:27 PM
BMRFIXIT
  • 19,053 POSTS
Car overheating
reason for overheating
bad thermostat
,water pump ,headgasket failure and so on have to be checked
also for the tranny sounds as you have a leak
need to be checked and located
Aug 21, 2009 at 11:33 PM
