1997 Mercury Sable Sutter Problem
107,000 MILES • 6 CYL • FWD • AUTOMATIC
COBIE72
Alright my problem lies within the shifting between first and second gears. If i was to take off from a stoppped position once the car trys to shift into second it shutters pretty bad but all gears after the fact shifts great. The thing I'm hoping for is it's an easy fix ha ha, but thats why i'm asking you because no one can anwser me so thank you for your time.
Jul 26, 2010 at 4:51 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 26, 2010 at 4:07 PM
