1997 Mercury Sable starts then dies
XANDERR
  • 1997 MERCURY SABLE
  • 6 CYL
  • FWD
  • 150,000 MILES
After car has been running for about 1/2 hour and is at normal operating temperature, the following problem occurs.
If I park and turn off motor, when I start it up again it dies. Specifically, it revs up to between 1500-2000 RPM, then steadily drops RPM until the motor dies after about 2-3 seconds.
Then, I have to wait until the engine cools off before it works properly.
Interestingly, if, during those 2 seconds when it’s running, I quickly throw it into gear and am able to start driving before it dies, it runs well. But that doesn’t always work.
Friday, September 17th, 2010 AT 12:15 PM
Hi Xanderr, Welcome to 2carpros and TY for the donation
Clean out the idle air control valve and EGR valve, then clean the MAF sensor with an electronic cleaner CRC and also test the throttle position sensor-
Friday, September 17th, 2010 AT 1:59 PM
LANIEPOO
  • 5 POSTS
Xander,
This is the same problem I seem to be having. I would be very interested in to the resolution to this problem. Was it the MAF? Or the EGR? Or the TPS?
Sunday, September 26th, 2010 AT 9:29 AM
MAF: Mass Airflow sensor, EGR: Exhaust Gas Recirculation, TPS: Throttle position sensor
Sunday, September 26th, 2010 AT 4:32 PM
