1997 Mercury Sable starting
120,000 MILES • 6 CYL • FWD • AUTOMATIC
K2IN
car will crank just fine but won't start when temp is 35- or colder. I can hook up cables and it will start just fine. put new plugs and wires, battery, coil pack. could you give me some help. it will run fine once started and will continue to start until it sits over nigt
Nov 1, 2010 at 9:17 AM
BILLYMAC
  • 2,204 POSTS
i would change the batt connectors at the batterry also put a new temp sensor in it the one for fuel injection not cooling
Nov 3, 2010 at 10:54 AM
