1997 Mercury Sable Heater Failure
ADMATHEWS
  • 1997 MERCURY SABLE
  • 6 CYL
  • FWD
  • 110,000 MILES
I have a 1997 Mercury Sable. Recently my heater has stopped working properly. If the car is stationary and running, the heater blows warm air but doesnt seem to be as hot as it should. When the car is being driven, it only blows cold air. What would I need to check to fix this problem. Any advice would be helpful.
Friday, November 21st, 2008 AT 9:30 PM
RENAUDTN
  • 636 POSTS
First check your level of coolant.
Second check your thermostat; Does your engine take a long time to warm up in the morning?
With the symptoms you describe, it sounds like your thermostat is stuck open (replace it).
Check the above and let me know if it doesn't fix your problem; we'll look at other possible problems.
Monday, November 24th, 2008 AT 11:02 AM
