1997 Mercury Sable Heat
118,000 MILES • 6 CYL • FWD • AUTOMATIC
PABLO656
the heat in my car stoped working today......i noticed that the temp gauge dosent go to half way, when i turn the heat on the needle goes all the way down to cold......
Oct 27, 2008 at 2:07 AM
RENAUDTN
  • 636 POSTS
Check your thermostat. It could be stuck open.
Turn your car on, and grab the upper radiator hose; you should feel no coolant flowing thru it until the car reaches normal operating temperature. If you do feel coolant when your engine is still cold, your thermostat is bad and you need to replace it.
Oct 31, 2008 at 6:55 AM
