1997 Mercury Sable dome light
97,000 MILES • 6 CYL • FWD • AUTOMATIC
BALDEY20
My dome light is suddenly staying on all the time my dash light says a door is open but they are not also on this car when reversing or going a certain speed the doors lock. this also stopped happening at the same time as the light problem any suggestions
Jan 25, 2010 at 3:21 AM
BMRFIXIT
  • 19,053 POSTS
Door switch inside door latch stuck
need the use of a scanner to conform which door and replace
most common is driver door
1st I would use penetrating oil and spray door latches
open and close door s few times and spray again
Jan 25, 2010 at 9:39 AM
