1997 Mercury Sable Check Engine Code
140,000 MILES • 6 CYL • FWD • AUTOMATIC
JSHOWN5
The check engine light came on and I had the system scanned. The code was P0174 and it seems that the most likely culprit is a Failed H02S21. Is it possible to change replace this part on my own and if so how do I proceed?
Apr 9, 2009 at 8:37 AM
OBXAUTOMEDIC
  • 3,713 POSTS
[quote:6d687421d9="jshown5"]Engine Mechanical problem
1997 Mercury Sable 6 cyl Front Wheel Drive Automatic 140000 miles
The check engine light came on and I had the system scanned. The code was P0174 and it seems that the most likely culprit is a Failed H02S21. Is it possible to change replace this part on my own and if so how do I proceed?[/quote:6d687421d9]
Here is the code def...
P0174 System too Lean (Bank 2)
If your vehicle is running fine then the most likely culprits are....
A bad O2 sensor and or an Exhaust Leak before the sensor.
It is fairly easy to change out an O2 sensor. There is a special socket to use in most cases other wise a wrench will work just fine. Your best bet to determine size is when you goto purchase the sensor have them get you the socket or wrench that fits.
Apr 9, 2009 at 8:52 AM
