1997 Mercury Sable 3.0 DOHC
95,986 MILES • 6 CYL • FWD • AUTOMATIC
PMARQ
I was driving the oil light came on i kept driving because i check the oil before i started to drive i figer it was a oil light glich about 5 miles down the road the car shut off and i can't get it to start is the engine fride and can it be rebuild
Apr 2, 2008 at 2:25 AM
BRAVESTAR1
  • 234 POSTS
If the Oil Light comes on, it means there is a problem.
Whenever you see that, it means that you need to not drive anymore.
Having driven more, and having this problem now. I think you need a new engine. Rebuilding it will cost more than a new engine would, as my guess is the crankshaft is in pieces and the cylinders have seized to the sidewalls. Probably a few other overheating issues with the block (warpage) and with the pieces of metal in the system it's a done deal.
Course the cost of a new Engine will likely be just as much as a newer Used car. So that may be your best bet.
Apr 19, 2008 at 9:04 AM
