1996 Mercury Sable Stumble Under Load
Check the converter on bank 1 And if you have never changed the oxy sensors it's time!
The highway mileage is 25mpg, city 12mpg. Just had the downstream 02 sensor changed on Bank 2.
Suggested Repair
Check the bank 1 catalytic converter for the P0420 catalyst efficiency code. Replace high-mileage oxygen sensors even if they are not setting codes; the recently replaced bank 2 downstream sensor can be left in place.
Conversation Summary
A 1996 Mercury Sable with a 3.0L OHV engine stumbles under load, briefly loses power, and the transmission comes out of gear before reengaging. Ignition wires and plugs were recently replaced, and a recurring P0420 code is present with no other codes. The expert advised checking the bank 1 catalytic converter and replacing oxygen sensors if they have never been changed, noting that sensors often do not set codes and are commonly due around 50,000 miles. The owner reported that only the bank 2 downstream sensor was recently replaced.
