1996 Mercury Sable when I shift out of park, radio turns of
PRINTER1967
  • 1996 MERCURY SABLE
  • 6 CYL
  • FWD
  • 113,000 MILES
When I shift out park, radio turns off, power steering does not work, power windows don`t work, power locks do not work. Shift to park every thing is fine.
Saturday, August 9th, 2008 AT 5:32 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a problem with the electrical part of the ignition switch. Have seen many Fords where the switch begins to fall apart and turning the wheel, moving the shifter, hitting bumps make all sorts of strange things happen. Switch should be on top of the steering column down about 2/3 of the way to the firewall.
Monday, August 11th, 2008 AT 2:29 PM
