ok...checked fuses ..good...checked auto lockout relay.. good. removed and checked master control
good continuety on all swiches including lockout switch all seems fine....heres the problem...
all windows work from main driver control...no windows work independantly...except driver window.
removed main control drivers side and opened up switch ...lock-out switch operating normally..no broken parts...also rear door lock switch at tailgate...wagon...does not work ...don't know if they are linked somehow or not. all other lock switches work fine...removed and checked pass side control no broken wires all seems fine good continuety.?????????????? please help..thanks
tomorrow is payday will gladly pay if you can help
Apr 9, 2010 at 10:18 AM
