1996 Mercury Sable Overheating
150,000 MILES • 6 CYL • FWD • AUTOMATIC
FFRECH
I have a 1996 Mercury Sable with the DOHC engine that started showing a high temperature. My mechanic said the thermostat was bad and replaced it. Problem not solved. The belt is turning the water pump shaft. I had taken the car to a local name brand tire dealership for an oil change and this problem cropped up after that visit. They are bunch of crooks (thought for a LOF would be OK) and I was wondering what they may have done to it to cause this condition.
Jun 20, 2008 at 4:27 AM
BLACKOP555
  • 10,386 POSTS
too low of oil can cause this problem if it heats up due to too much friction.
check the level.
other than that i dont know what they could have done, maybe disconnect a o2 sensor or mess with the timing?
Jun 20, 2008 at 5:32 AM
