1996 Mercury Sable lower ball joint replacement
1996 MERCURY SABLE
102,000 MILES • 6 CYL • FWD • AUTOMATIC
ZEBULA
How to remove the lower ball joints and replace them. Thankls
Jul 25, 2009 at 3:24 AM
F4I_GUY
  • 3,302 POSTS
Mitchell 1 OnDemand states that the lower balljoint is pressed into the steering knuckle. It states that the knuckle must be removed to press the balljoint in and out.
However, if you can purchase a balljoint remover/installer kit, you can do it on the vehicle. Do you have access to this tool? If not, the removal of the knuckle requires a spring compressor for the front coil springs. Either way, you need some speciality tools.
Jul 25, 2009 at 3:39 AM
