1996 Mercury Sable help!
JETTYD22
Shakes or Wobbles problem
1996 Mercury Sable Engine Size unknown Two Wheel Drive Automatic 100,00 miles
So I bought this sable wagon about 3 months ago. I even had it looked at before the purchase. It would shake if I tried to speed up to quickly. But today it will not shake but is just taking a long time to speed up (over 10-15 mph) it also sounds like the engine is revving. I am scared I bought a lemon.
please help.
Mar 21, 2008 at 5:43 AM
SERVICE WRITER
  • 9,123 POSTS
Did you check the transmission fluid level?
Is it full and clean?
Not sure if this is a transmission issue or a performance promblem.
Do you mean the engine revs, but the car goes no faster?
Mar 21, 2008 at 6:02 AM
JETTYD22
i have not but i will now:) yep that is exactly what it does.
Mar 21, 2008 at 6:03 AM
SERVICE WRITER
  • 9,123 POSTS
Hopefully you'll get lucky and it is just low fluid. However damage may have been done to it from running it low. And also there is probably a leak that need to be found.
Mar 21, 2008 at 1:04 PM
