Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Sable
Engine
Symptoms
Not Running
1996 Mercury Sable dtc codes
1996 MERCURY SABLE
93,796 MILES • 6 CYL • FWD • AUTOMATIC
BBURKE3178
MEMBER
1 POST
CAR WILL NOT START AND I RUN THE DTC CODES AND HAVE 3 CODES PO171,P0174,P0401 AND IM STILL NEED A LITTLE ADVISE ON SPACIFIC COMPONENTS TO CHECK
Dec 15, 2008 at 5:09 AM
DOCFIXIT
Experienced Mechanic
Check fuel pressure your lean on both banks. Also EGR flow problem check for vacuum leaks.
Dec 15, 2008 at 6:46 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
