1996 Mercury Sable 6 cyl Front Wheel Drive Automatic
my temperature goes from normal to cold while driving when heat is on and off I flushed the system, replaced thermostat that didnt work so I replaced the water pump and it still continues oh also changed the radiator cap I have no clue what the problem is or what to check next if you can help that would be great
SPONSORED LINKS
Friday, October 10th, 2008 AT 8:35 PM
