1995 Mercury Sable won't shut off
OAKDALE
Electrical problem
1995 Mercury Sable 6 cyl Two Wheel Drive Automatic
turn ignition off, engine still runs. put in park and steering wheel or transmission won't lock. have to pull coil wire to stop engine and disconnect battery to shut off power to everything.
Jun 30, 2010 at 12:34 PM
BMRFIXIT
  • 19,053 POSTS
Ignition switch actuator rod
Easiest way is to remove and replace the steering column
Jun 30, 2010 at 1:56 PM
