1995 Mercury Sable Whine on Decel
FAIRYGLOW
My 1995 V6 3.0 L Mercury Sable with 165000 miles has just started whining when you take your foot OFF of the accelerator. When it is idling it sounds normal. It acts normal otherwise. It is shifting fine and the transmission fluid is full and red.
It started last week. It was making a jet kind of sound when you accelerated and a small whine when you took your foot off the accelerator. THEN after a couple of days the jet sound stopped and the whine got really loud.
Any ideas would be helpful! Thanks!
Feb 28, 2007 at 6:47 AM
MERLIN2021
  • 17,250 POSTS
Tell me were the noise is comming from? Engine or transmission? or maybe the exhuast?
Mar 4, 2007 at 7:38 PM
FAIRYGLOW
thanks for offering some help. I believe it is coming from the Transmission because it does not do it if I'm in park and rev the engine. It also gets quieter when I'm driving and put it in nuetral, although it does not go away entirely. Sitting in the drivers seat, I can hear it coiming from the left side under the hood.
Mar 5, 2007 at 7:24 AM
MERLIN2021
  • 17,250 POSTS
you could have a carrier bearing problem, This is were the 2 axles go into the transmission. Any fluid dripping out there? Don't forget to vote! You could also have a wheel bearing issue. Try steering a little left or right real quick and see if it goes away! let me know PM me P.S. Wheel bearing don't usually "Growl" til ya get to 30-35 MPH!
Mar 5, 2007 at 7:29 AM
Suggested Repair
Inspect the transmission carrier bearing where the axles enter the case and check for fluid leaks there. Also test the wheel bearings by briefly steering left and right to see whether the whine changes.
Conversation Summary
A 1995 Mercury Sable with 165,000 miles developed a loud whine when the accelerator was released, after an earlier jet-like sound during acceleration stopped. It idled and shifted normally, and the transmission fluid was full and red. The owner believed the noise came from the left side of the transmission because it did not occur when revving in park and became quieter in neutral. The expert suggested checking the carrier bearing at the axle entries for leaks and testing the wheel bearings by steering slightly left or right.
