1995 Mercury Sable wheel bearing replacement
1995 MERCURY SABLE
208,000 MILES • 6 CYL • FWD • AUTOMATIC
JAKERHODES82
I am trying to replace the wheel bearing on my 95 sable and i have the rotor and hub off but how do i get the bearing out? do i have to take the knuckle apart or is there an easier way?
Nov 1, 2010 at 5:19 AM
SATURNTECH9
  • 30,869 POSTS
Two option's remove the knuckle and have the old bearing pressed out and the new bearing pressed in.If you do it that way you will have to have the car aligned.The second option buy a on car wheel bearing remover and installer and use that to replace the bearing.
Nov 1, 2010 at 7:08 PM
