1995 Mercury Sable no heat
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN RYALS
get heat sometimes. not often.what are possible problems
Jan 13, 2009 at 7:53 AM
RENAUDTN
  • 636 POSTS
-Low coolant
-Air in cooling system
-bad thermostat
-clogged heater core
-broken blend door/blend door actuator
-If your car is equiped with a heater control valve, it could be stuck shut or you could have a vacuum leak.
These are the most common problems.
Jan 13, 2009 at 9:09 AM
